3d trainer Maya_nCloth_Part 1Description: 3d Trainer tut Maya nCloth Part 1
1.Setting you playback preferences is an important part of getting accurate simulations in your nCloth objects.
2.Through out these nCloth tutorials we will be using a custom shelf. This chapter will show you how to create your own custom shelves in Maya.
3.This chapter will cover the basics of creating an nCloth object from polygon geometry. You will also learn how to create passive objects for you nCloth to interact with.
4.A Transform Constraint is a great way to attach your nCloth object to other pieces of geometry.
5.One of the many great features built into nCloth is that ability for you to interactively play back your simulation. This allows you to make changes to your cloth object during playback.
6.This chapter will cover all of the options that you will find located under you nCloth pull down in the main menu bar.
7.Setting the initial state of your nCloth will give you the ability to set its start position for the beginning of you simulation.
8.nCloth allows you to directly paint many of the cloth properties directly on the surface of your cloth object. Properties like stretch, wrinkle, and righty.
9.This chapter will cover the main different types of dynamic fields that can be used to control the movement of your nCloth objects.
10.It is important to remember a few rules when setting Keyframes on fields to avoid undesirable results.
11.This chapter will cover the enable feature located in the attribute editor under the nClothShape tab.
12.This chapter will cover the collide and self collide features located in the attribute editor under the nClothShape tab.
13.This chapter will cover collision layers located in the attribute editor under the nClothShape tab.
14.This chapter will cover pressure located in the attribute editor under the nClothShape tab.
15.This chapter will cover tearable surfaces located in the attribute editor under the nClothShape tab.
16.This chapter will cover glue strength located in the attribute editor under the nClothShape tab.
nClothShape node
17.This chapter will cover thickness located in the attribute editor under the nClothShape tab.
18.This chapter will cover solver display located in the attribute editor under the nClothShape tab.
19.This chapter will cover friction and mass located in the attribute editor under the nClothShape tab.
20.This chapter will cover lift and drag located in the attribute editor under the nClothShape tab.
21.This chapter will cover stretch resistance located in the attribute editor under the nClothShape tab.
22.This chapter will cover compression resistance located in the attribute editor under the nClothShape tab.
23.This chapter will cover bend resistance located in the attribute editor under the nClothShape tab.
24.This chapter will cover bend angle and drop off located in the attribute editor under the nClothShape tab.
25.This chapter will cover deform resistance located in the attribute editor under the nClothShape tab.
26.This chapter will cover shear resistance located in the attribute editor under the nClothShape tab.
27.This chapter will cover restitution angle located in the attribute editor under the nClothShape tab.
28.This chapter will cover restitution tension located in the attribute editor under the nClothShape tab.
29.This chapter will cover gravity and wind located in the attribute editor under the nucleus tab.
30.This chapter will cover the use of a ground plane located in the attribute editor under the nucleus tab..
31.This chapter will cover the solver attributes located in the attribute editor under the nucleus tab.
32.This chapter will cover the time attributes located in the attribute editor under the nucleus tab.
33.This chapter will cover the scale attributes located in the attribute editor under the nucleus tab.
после того как введете ссылку в браузер и нажмёте энтер,
в самом вверху будет надпись- Skip this ad, жмите на неё и появится ссылка для скачки.
архивы примерно по 40мегов,а последний 2мб.
CODE
[url=http://www.mytempdir.com/1365121]http://www.mytempdir.com/1365121[/url]
[url=http://www.mytempdir.com/1365135]http://www.mytempdir.com/1365135[/url]
[url=http://www.mytempdir.com/1365149]http://www.mytempdir.com/1365149[/url]
[url=http://www.mytempdir.com/1365160]http://www.mytempdir.com/1365160[/url]
[url=http://www.mytempdir.com/1365173]http://www.mytempdir.com/1365173[/url]
[url=http://www.mytempdir.com/1365195]http://www.mytempdir.com/1365195[/url]
[url=http://www.mytempdir.com/1365198]http://www.mytempdir.com/1365198[/url]
