Блоки питания - The Good, the Bad and the Ugly., "BLACK LIST" and "GOOD LIST" |
14/02/2006, 09:21
Эксперт Группа: Участник Сообщений: 793 Регистрация: 12/09/2004 Из: Atlanta Пользователь №: 7 438 |
First: the list to avoid. Не покупать ни за какие деньги!
List shamelessly ripped off from Hardocp, but with some revisions. Achieve Aerocool Allied Aspire I wouldn't touch this power supply with a 50 foot pole. It doesn't meat ATX spec, the rating scales are nonexistant on this supply (no temperature measures, accurate amps, wattage jump). Lots of people seem to want one cause they're bling bling. Don't. Doesn't meet basic safety spec. Codegen Coolmax: OK power supplies, but far from the best. Demon: Made by Powmax. Possibly one of, if not the absolute worst manufaacturer of PSU's. See below. Deer: Makes L&C power supplies. See below. Devanni. Dynapower Eagle InWin JustPC Kingwin: The ones included with cases are crap the ones that are sold seperatly are ok. L&C: Made by Deer. Your typical craptastic generic psu that doesn't put out enough amps, and dirty power. Linkworld MGE: Same OEM as the Ultra X-connect (Taiwan Young Year). Doesn't meet required Power-Man Powmax: The absolute worst Power supply manufacturer in the world. Ever see a PowMax 450w get beaten by an Antec 250w? How about the 12v that is rated for 20a, but it blows before it even hits 17? Avoid at all costs. Power-Up Raidmax Thermaltakes: Not so bad as some of the above, but still pretty damn bad. The PurePower 680w rating is mostly from the 3.3+ and 5+ rails, not the 12v, where it counts. If possible, get something else. If not, then settle for a higher end. Ultra X-connect: Early production models (2004) made by Wintech. Starting from 2005 onwards, the OEM switched to Taiwan Young Year, and the new ones just plain SUCK. Avoid. The X-finity's are fine though. X-superalien: Made by Powmax. See above. X-treme DO NOT buy any of the above. Here is a list of the good, and some descriptions. Antec: Sometimes silent, sometimes not. Pretty reliable, but quality seems to be going downhill. Still an extremely good deal. Akasa: Same OEM as Silverstone Enermax: Good, silent power supplies. Quality seems to be slipping a bit, but still right up there. Fortron (FSP): Damn good deals, and some of the best psu's I've ever seen. OCZ: Powerstream is the second best PSU you can buy, right behind the PCP&C 510. Sunbeam: Good, cheap, modular. SLi certified. PCP&C: The best psu's ever. Military Spec. Silencers made by FSP. Zippy: A bit on the expensive side, but right up there with PCP&C Zalman Tagen Coolermaster: No Active PFC, but still a decent supply Vantec Sparkle: OEM'd by FSP Silverstone: The 650w Zeus is a very good supply, if not a bit loud. Seasonic: Very, very good power supplies, and very quiet at that. SilenX: OEM'd by FSP Xclio: Same OEM as Antec Vantec HiPro И напоследок рейтинг Блоков питания начиная с самых плохих и заканчивая самыми лучшими (внизу) Deer Allied Powmax Dynapower (they even have bogus UL numbers on them!) Raidmax (the ones that come bundled with a Raidmax case. Not necessarily one you'd buy separately.) Rhycom Achieve/Viomax Turbo Links that are made by "Real Power" (like the ones that are included inside Aspire cases.) Rosewill (various manufacturers, but usually fair quality.) Coolmax and some other ATNG manufacturered units. Low end Wintech's (like Ultra V-Series and some Turbo Links) FSP Saga series (AX part number) Youngyear (includes some older Ultra X-Connects, MGE's and Aspires.) A.C. Ryan Enlight (used to be Enhance, but now seem to all be ATNG's) TTGI/Superflower FSP/SPI (those with FSP part numbers.) Topower P5 based units (like OCZ Modstream, Tagan, most ePowers.) Most Thermaltakes Most Wintech (most Ultra models, Sintek, Future Power, some MGE's) Topower P6 based units (like the OCZ Powerstream.) AcBel Polycom (Coolermaster, for example.) Antec XClio Sunbeam NUUO series PC Power and Cooling Silencer series Ablecom/Supermicro Delta AMS Mercury Seasonic Enermax Enhance (includes some Silverstone units) PC Power and Cooling Turbo-Cool series Zippy/Emacs Etasis (includes some Silverstone units) для тех кто хочет знать больше - original link Сообщение отредактировал Gleb_ATL - 14/02/2006, 09:22 |
14/02/2006, 09:46
Гость, просто гость... Группа: Участник Сообщений: 2 980 Регистрация: 28/08/2002 Пользователь №: 651 |
да да. как всё хорошо
увы купить в Москве без гемороя можно только OCZ и Zalman |
14/02/2006, 10:00
Я себе летом купил Enhance 400W (взамен "встроенного" в корпус Powerman 300W) - долго не мог понять, хорошая фирма это или нет (правда на вес Enhance раза в два тяжелее чем PowerMan) и цена меня поначалу смутила - всего 1250руб.
14/02/2006, 10:50
Как-то слишком категорично...
14/02/2006, 11:17
QUOTE(Wisky @ Feb 14 2006, 17:50) Как-то слишком категорично... [right][snapback]575738[/snapback][/right] присоединяюсь. Например Thermaltake "не брать ни за каие деньги" - это явно черезчур. Очень приличные блоки из тех что у нам свободно продаются. Хотя у меня как-то Zalman'ы прижились в последнее время. |
14/02/2006, 11:43
QUOTE(Wisky @ Feb 14 2006, 03:50) Как-то слишком категорично... [right][snapback]575738[/snapback][/right] а как тебе такая ситуация когда на блоке написано 500ватт, при этом 300ватт идет по 3.3 и 5вольт "rail"(дёшево в производстве) а на 12вольт "rail"(дорого в производстве) только 200ватт? результат - читаю ссылку "...Do not get a power supply with a higher amperage on the 12V rail than on the 5V rail. I know future-proofing is a usually a good thing to do, but typically when a power supply with a high 12V capability is hit with a heavy 5V load, even when it's within spec, there's a thing called "crossloading" that happens. Essentially, your 5V dips below tolerance and your 12V shoots above. Side effects include lock up or even system shut downs due to over or under volt protection!" плюс куча других скрытых проблем - Power Factor, Hold up Time, Power Good, Efficiency at minimum and at full load, Remote DC Sense, Active Power Factor Correction. Столько всяких фирм с красивыми и дорогими коробками развелось а что там внутри? А качественное питание - залог здоровой системы |
14/02/2006, 11:59
QUOTE(Barsuk @ Feb 14 2006, 04:17) QUOTE(Wisky @ Feb 14 2006, 17:50) Как-то слишком категорично... [right][snapback]575738[/snapback][/right] присоединяюсь. Например Thermaltake "не брать ни за каие деньги" - это явно черезчур. Очень приличные блоки из тех что у нам свободно продаются. Хотя у меня как-то Zalman'ы прижились в последнее время. [right][snapback]575756[/snapback][/right] У меня Thermaltake PurePower Power Station 520 Watt -$160 выключался просто так в течении сессии. Потом не включался минут 20, потом работал пару дней патом опять всё па новой. Переставлял на два разных компа - то же самое. Купил после него PC Power and Cooling 510 - земля и небо. Zalman 400W - очень тихий. то есть в прямом смысле патаму как не включился вообще. пролежал где-то год на полке (думал что там предохранитель сгорел а поменять руки не доходили) а потом пытался связаться с Zalman тех поддержка но там все вопросы пользователей без ответа годами лежат - зайдите на их форум на сайте и почитайте. Мне просто попалась ссылка патаму как ищу гарантию на стабильную работу одинаковых блоков питания для 10 станций (в перспективе ). Рассматривайте её как руководство а не догму. вот еще один неплохой линк TrustedReviews - ATX Power Supply Group Test PS. Кстати к вопросу о доступности. Мне вот подходит такой ETASIS EFAP-462 2U/3U Format при этом вентилятор 80мм - а найти в продаже пака никак! Сообщение отредактировал Gleb_ATL - 14/02/2006, 12:09 |
14/02/2006, 13:13
Zalman 400W у меня есть, нормальные блоки. Но новый 460вт, 120мм, получше будет. На разогнанном Х2 3800+ и 6600GT практически не шумит под нагрузкой. 400-ваттник на редеринге все же погромче был, немного.
Thermaltake'и юзал W0008 серии с двумя вентиляторами, тоже кстати негромкий был. Что с залманами, что с термалтейками проблем не было. Нагрузку держали хорошо, выдерживали скачки напряжения в сети: компы с этими БП и без UPS, не вырубались, в отличие от своих рядом стоящих собратьев. смотрю, не везло тебе с БП Тестирование семнадцати БП от 400вт и выше, присутствуют модели из вышеприведенного списка. |
14/02/2006, 13:24
Глеб - согласись - твой пример далек от статистического.
У меня так Пауермен мог выключится когда напруга падала ниже 180 вольт или втыкал УСБ в незаземленный слот. На моей памяти было куплено с десяток корпусов термалтейк Хазер3 под ксеоны - в течение года сдох один на 450 Вт, на машине (2ХNocona+GF 6800GTX ) стояло 8 хардов+2привода и 7 вентиляторов. Сменили на аналогичный 520 - пашет уже полтора года. При том, что и термалтейк и Пауер-Ман если сдыхают - то сдыхают автономно. Если сдыхает железяка (КЗ на матери по УСБ), то железяка сдыхает автономно - БП отрубается и они не тянут за собой все остальное железо. Инвин- да есть ощущение, что как-то расслабился - а ведь делал отличные корпуса и БП. И все это при том, что даже если я упрусь и мне повезет, я найду новомодный БП из "белого" списка, нет никакой гарантии что его не переморозили, пока везли или хранили, и он так же не загнется от КЗ или чего-то там еще. С гарантией я потом намаюсь - мама не горюй. А если речь идет про 10-15 компов - тем более - собирать надо из конкретного ширпотреба. Обжигался на этом не один раз. Посредине проекта сгорела мать - редкий изврат(Асус Р5Р800), но в городе доступная - оставил в гарантии, в это время поехал и купил такую-же. минимум затрат на сборку/совместимость железа/перестановку дров. Кстати, это же касается и нахваливаемых тобой Раид-контроллеров. Они могут быть хороши сами по себе, но без возможности замены на аналогичный в ближайшем ларьке - они никакие. Степень доступности, сервиса и взаимозаменяемости - вещь далеко не последняя. |
14/02/2006, 14:10
в благоприятных условиях и плохой блок будет работать хорошо и долго, но это не его заслуга
согласен что к любой информации нужно относится с изрядной долей скептицизма, тем не меннее в приведенном линке на оригинал есть информация о реальном производителе почти всех марок БП. Если есть хоть даже минимальный выбор - то легче определиться имея данный список под рукой. В серверных стоечных решениях надежность стоит на первом месте а информации о них очень мало. Например ZIPPY и FORTRON (FSP)используются многими крупными производителями (Интел, Sparkle, Dell) под своими собственными брендами. тот же ZALMAN - FSP, мне просто не повезло! Например узнав что блок Emacs это на самом деле ZIPPY мне гораздо легче сделать выбор. |
14/02/2006, 14:38
с приходм товарища Gleb_ATL здесь стало гораздо интреснее. Иногда даже интересные для себя вещи нахожу...
14/02/2006, 14:42
Опять же, к нам не повезут просто так, на шару, не раскрученного производителя за бешенные деньги. А за копейки - стопудово - подделка.
Штучные заказы делать через конторы торгующие проф. железом - это просто разорительно. |
14/02/2006, 14:46
MaxMan Группа: Участник Сообщений: 241 Регистрация: 11/03/2005 Пользователь №: 10 984 |
Полезная инфа про питатели:
http://people.overclockers.ru/Overclocker/record12 |
14/02/2006, 14:55
QUOTE Опять же, к нам не повезут просто так, на шару, не раскрученного производителя за бешенные деньги. А за копейки - стопудово - подделка. Штучные заказы делать через конторы торгующие проф. железом - это просто разорительно. про что и речь к сожалению... а вы тут про zippy душу мне корябаете |
15/02/2006, 08:21
Как по заказу, Свеженький обзор десяти мощных БП:
http://www.toms-hardware.ru/howto/power_su...2006/index.html |
Текстовая версия | Сейчас: 25/04/2024 - 11:25 |
